griff
Saw the other thread about this. Mine is a bit different in symptoms.
1992 Bronco, 5.8L.
I have new battery showing 12.5 volts, alternator showing 14+ volts while running, new fuel pump relay installed, ground by battery secure/no corrosion.
Car can start when I hear the primer finish (usually 3-5 sec). Will not start due to primer noise in rear signaling stuck on/open.
Frustrating because I am needing to buy lumber for a job before cold weather sets in.
Do I need to be making plans to get a new fuel pump? Or is there another check to see if I can avoid it?
Thanks,
griff
1992 Bronco, 5.8L.
Thanks,
griff
