Rotor change
Kal-El
I want to change the rotors on my 91 Bronco with automatic 4 wheel drive. The parts stores just sell the rotors; however, my rotors and hubs are connected. I have not been able to find a store who has what I need. Do I have stock rotors and hubs on mine? If so, can I buy them as together or do I have to separate the hub from the rotor some how? Any help is appreciated.
bluesman17
Spam Terminator
South Bend, Indiana
Your rotors are hubs arent connected, but you have to remove them completely from the truck to knock out the studs and then seperated them with a ***** driver or cold chisel (probably rusted together a bit). Remove the hubs and locknut washers to get the rotor off. Good luck :)>-
K
Kal-El
Thank you for the help. Where is the lockout washer?
bluesman17
Spam Terminator
South Bend, Indiana
Behind the hub assembly its pretty big and you need a locknut wrench to get it out (6 bucks i think) if I remember right there may be two but not positive on that.
K
Kal-El
Thank you for all your help. I took the rotors off last night and decided I should change the bolts while I was there. After I hammered out the last bolt, the hub fell off. I got the job done last night. It would have been nice to have the whole assembly but everything works. Again thanks.
