ripped shackle bracket
wtfdissux
Buffalo, NY
was driving home last night and got tired of the clicking noise on bumps and start stop when i looked under found my LR shackle mount has about 1/2 inch of metal left before the shackle says good bye to frame of course the bolts on shackle wont come out and am about half way through the bolt end ( on my fourth cutoff wheel ) and realized i dont have any idea how the **** i am gonna get the rest of the bolt out dont really have enough oxy left for torch and not able to get bushings till nex week need info on how to proceed with removing the shackle from mount from there it cant be much worse that rad arm brackets i hope [-o<
yo!
I need more cut-off wheels too! Just went through 6 doing some cutting @ my bro in law's
Can't help you from here; exc. to get more Gas or more wheels.
anyway here is some info on reversals w/pics
Big red http://fullsizebronco.com/forum/showthread.php?threadid=5391
Froggman http://www.froggmann.com/Bronco/Tech/Shackle.htm
ocalabronco
ocala, Fl
if your on a tight time table, chances are its gonna take forever (thats been my luck at least). see if you can borrow someones car or snag a ride to work. that will free up some pressure. otherwise, buy alot of cutoff wheels and call a J/Y
W
wtfdissux
Buffalo, NY
Went and bought a 4 inch grinder today and removed outer side of the shackle (found it is bad as well). The top nut actually came off and that bolt almost moves free from the bushing. But have been pounding with a 5 lb. sledge and punch on the lower it wont budge from the bushing have soaked with PB blaster for going on 2 days now.
So basically am stuck at that point, cant get the bolts out of the shackle bushings. Can't cook them out as I am out of O 2 and cant get a new tank till after next weak
Only bright side is the shackle($12 from dealer)comes with the bushing pressed in and bracket ($40 from dealer) and both are in stock.
but if they don't come off the damn truck kinda hard to change them.
needed to move the truck to get my 88 out of garage so can make it to work that was a fun trick with a narrow driveway on 1/2 a shackle.
Ford644
