rides ROUGH
Micah_86
MY bronco rides really rough and its only an 86 im not quite sure what aproach to take. Do i need to get any better shocks or what? please help. Thanks.
Billz4x4z
Carnesville,GA
Shocks is your 1st replacement,go with a good gas shock,If that doesn't help then your lookin at gettin new springs...If its saggy in the rear you might wanna do shocks and springs.
M
Micah_86
Thanks how much would that end up costing? Any idea? Thanks for the help.
Billz4x4z
Carnesville,GA
Check some of the 4x4 magazines alot of them have specials on 4 shocks...4 shocks shoul get between 150-200+ depending on what ya get.....cheaper if your just gonna go your basic gas shock.
Broncoholics
Broncoholics
Washington State
Take a shock off up front if its stiff so you only have one per corner. Sounds like the suspension is fine if its stiff still. I went with a trailmaster suspension and shock on my 89 because its cheap and soft.
That may work if you have the quad shock front.
A new set of four or six offroad shocks like ProComp or Rancho will run $120-$150.
guilhermeknob
