rich fuel mixture
murph
North Carolina
My Bronco is running very rich. Everyone tells me to adjust the mixture but I can't find the procedures in the manual. Its a 91 with a 351W. Any help?
Wait Wait Wait you have a 91 with a carb ? Im not thinking so unless you or someone else has changed the intake and went to a carb system . If you fuel injection system is running rich there is a couple things you can check . Make sure the fuel presure is not too high , The coolant temp sensor may be bad telling the EEC that the motor is cold all the time , When was the last time you changed the air filter ? Have you ran any type of injector cleaner through it ( may have an injector hanging open ) If its fuel injected like its suposed to be try that stuff :D /emoticons/[email protected] 2x" width="20" height="20" />
ocalabronco
ocala, Fl
also check your 02 sensors. those can send a bad reading to the comp, causing it to create a rich idling enviroment
Ford644
