S2LEGEND
legendary in my own mind.
Hey everyone. Need some guidance/suggestions. Here's the story:
THE PATIENT:
1989 Ford Bronco XLT
4.9L FI 6cyl, 5 speed manual
118k miles
THE SYMPTOMS:
heavy fuel odor
runs rich
fouled plugs
hard starting, need to use the throttle to fire it up
exhaust is white-ish upon startup
erratic idle with a 300 rpm surge and drop. does not stall.
THE TREATMENT:
I've changed the AIC, and put the factory spark plugs in.
Oil change was also done.
timing was set 10 degrees BTDC
There is a hole in the A.I.R. tube going from the cat back to the motor.
IDK what else to do. I was thinking it might be the Fuel Pressure Regulator. The odor is fouling my interior /emoticons/[email protected] 2x" width="20" height="20" />
Suggestions?
Thanks, B)
Phill
THE PATIENT:
118k miles
THE SYMPTOMS:
heavy fuel odor
runs rich
fouled plugs
THE TREATMENT:
Suggestions?
Thanks, B)
Phill
