johnnyreb
You can save yourself alot of trouble and aggervation . Get 2 cut off valves. Put them in where they are easy to reach. If a leak occurs all you have to do is turn the valve off and when you make the repair . Open the valve back up. They are also good for when you replace the hoses,heater core or during an emergency if one should blow a hose. Also when you need to flush the cooling system. Both should be left in.
