Recommended upgrades?
opy
South Carolina
So, I have the B&M megashifter in, Heddman long tube headers with Magnaflow exhaust, removed smog pump, no cat, EGR plugged. What are the recommendations for upgrading the 351W in my 1992 Bronco now? I don't want to go internal, just minor upgrades that will help increase performance and maybe even gas mileage. I have heard and read many mixed opinions on items such as cold air intakes, computer chips etc...
AdamDude04
"H-Y-B-R-I-D" as commonly found on the lower portion of Chevy Tahoe/Suburbans
This won't add any power.. but it'll make them tree hugers get off your back :-"
There is a "ghetto" CAI mod that uses a chevy air filter and a small peice of PVC pipe. Much cheaper route than the actual kit..
zintrex
i dunno if the system im bout to write bout is the same as adam's post but heck more info the better.
If you are looking for better fuel economy there is one thing you migth want to consider. LPG DRIVE
i dont know how common it is in the US but over here in europe its pretty common.
so what is LPG drive?
well basicly its an addon kit you can install in your car that lets you run on LPG gas, (propane)
-the most basic systems is almost a hose into the intake (uses a mixer u install on the tube between trottlebody and air filter)
and vacume valve that feeds gas according to map pressure. (stay away from theese kits they use a lot of gas and are way outdated)
Theese kits shoud only be used on carburettor cars, (or so says all the pro's ive talked to)
- the next step up the ladder is a oxygen sensor (hego) system. and this is a good option for us bronco pilots.
The basic idea is a gas drive ecu that feeds of the stock petrol sensors and the calkulates how much LPG to send to the mixer.
Theese kits work wery well on early (pre 1995) efi cars, and on carburettor cars,
but shoud NEVER be installed on a car with a plastic intake maifold due to possebilety of backfire.
both of these systems uses a unit called a Emulator to fool the stock petrol pcm to think the injectors have been fired when they have been closed.
and is reliant on the stock pcm to control ignition idle and so on.
The last type of system is a VSI system (vsi = Vapor sequential injection)
Theese sytems are pretty adwanced and works in a very simular way to our stock petrol efi PCM's
with iduvidual gas injectors for each cylinder.
the vsi systems usualy uses a hego sensor and input from the stock sensors. BUT require programming of the vsi pcm to work properly.
most vsi systems uses emulators to turn off stock petrol injectors and fool stock pcm to think nothing is wrong.
all theese systems lets you drive ur car on propane,
Yes, with the first 2 systems you will loose some power when ur driving on gas, but hey its damm cheap.
with a properly programmed VSI system you will not loose much power and they use less gas then the other 2.
On ALL of theese systems you can change from petron to gas and from gas to petrol wo any issues and while driving.
all modern systems have decent emulators and control units.
some other considerations when running a car on lpg,
1 ur engine shoud be in good working condition.
2 if you have a tiny crack or a developing crack in ur cast iron headers, exspect it to get bigger.
lpg burns a little bit hotter and on lpg ddrive old cast iron headers migth crack. myself im getting tubular headers for my bronc.
3 LPG gas has a octane rating of 110, but all engines ive seen that runs lpg runs great and smooth.
http://en.wikipedia.org/wiki/Octane_rating
4 u shoud read about it and make shure u know what ur doing if you are doing it urself.
A badly installed lpg system that leaks can be very dangerus. so best thing is to have a pro either install it or test it for you before first fillup.
5 I have NO idea on how inshurance companies in the us thinks about lpg converted cars.
6 LPG drive only works as on petrol cars, on a disel car you have to mix disel and lpg, and is mostly only used to help reduce fuel cost.
I hope my post has been useful, and sorry for bad grammar and spelling error's my native language is Norwegian not english
Edit:
as an added bonus, your petrol system is untouched, so if you want some performance, just press a button and boom ur back to the good old petrol,
Krafty
Ontario Canada
being as you already have the exhaust done the next 3 parts of the equation are Fuel, spark and Air. With the exhaust upgrades you have great air ( exhuast)flow coming out of the motor, now you need to get more air going into it. Cold air intake kits are a good way of doing this, apart from getting a new intake manifold that flows better. another option is porting out the original intake with a die grinder when its removed from the engine.
now spark... High energy ignitions are a great choice, otherwise just ensure you get a spot on timing check and new plugs and wires.
Lastly Fuel... Larger capacity fuel injectors, matched with slightly higher pressure pump and a perfectly operating Fuel pressure regulator.
and top that off with a programmer or pre programed chip to account for better exhaust flow, air flow, spark, and fuel flow.
anything other than that and you are tearing into or adding onto the motor. ( supercharger, turbo charger, Nos, cam, heads, bigger bore, longer stroke, and bigger valves)
opy
opy
South Carolina
I am considering an MSD 6A ignition box with an MSD Blaster TFI coil. Will this improve performance/efficiency or just look real cool under the hood?
Krafty
Ontario Canada
You may need to look up dyno results of that ignition combo, as far as I know pretty much anything is an upgrade over the duraspark III system
