Rear seat pivot pin
Rocknbrnco
Panama City, Florida
I removed my rear seat from my 1995 years ago and need to re-install. Found all the hardware except for the rear seat pivot pins. I went to the Ford dealer but was told it was no longer available. He suggested I use a bolt but I am not sure this is the safest method. I have a four month old grand daughter who must ride in the rear seat. The part number is 60520. I must take my Bronco to the airport because my family and I are going home for Christmas (way too much luggage!). Any suggestions would be greatly appreciated! Thanks!
yo Rock,
Here is da Rear, Bench Seat Mounting & Parts Break-Out Diagram in 92-96 Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
In lower Right side of this diagram;
It shows the Hinge Pivot Pin as Ford PN 63022
and the Rear Seat Cushion Pivot Bracket as pn 60520
Same diagram & Part numbers as in the Workshop Manual by Ford via Chilton
For the Child Safety Seat, Tether Attachment, Bronco
btw, I had the rear center done at loacl dealer 3 years ago and it is still availbale' The roght and left sides are as well. "AVAILABILITY; "...the 92-96 kit is still available, but you need to special order it from the "classic" catalog. I just had two brought in by my local dealer at around $35 each..." posted on 26 OCT 2010 Source: by Ryan87LX"
The installation and the kit(s) for all 3 positions are FREE
Service Instructions; For 89 and later models & F-Series Source: by Ford via miesk5 at Miesk5's Home Page of Big Bronco Links
Item Part Number Description
1 67412 Latch, Rear Seat Cushion
2 387871-S2 Bolt, Rear Seat Cushion Pivot Bracket
3 387871-S2 Bolt, Rear Seat Back Latch Striker
4 111B42 Rear Floor Pan Opening Cover Plate
5 62440 Rear Seat Back Latch Striker
6 388092-S2 Spring Retainer
7 63120 Rear Seat Cushion Spring
8 63022 Hinge Pivot Pin
9 67438 Spring
10 60520 Rear Seat Cushion Pivot Bracket
11 604K22 Rear Seat Cushion Torsion Bar
12 378444-S Plug
13 387871-S2 Bolt, Spring
A — Tighten to 54-81 Nm
(40-60 Lb-Ft)
THE GOOD NEWS IS THAT NPD HAS THE PIN!!!!!!!!!!!!
see; http://npd.dirxion.com/guide/NPD2010BroncoCatalog/7.asp
$3.50 each
Send me a PM with your address in it and I will send you one. I've got a few of them in the garage.
R
Rocknbrnco
I really appreciate eveyone's quick response. My best friend passed away the day after I posted this quesion. My wife checked the replies, saw the web page recommended by miesk5 and ordered the parts. Seabronc, thank you for the offer. I guess I have to learn the proper way to post a question. My apologies. I will be in the process of restoring my 95 and will rely heavily on everyone's assistance from this forum. Again, thank you all for the replies and your time. I wish you a Merry Christmas and a healthy and happy New Year.
Chapin1736
