Yo wobbly-pop,
As johnnyreb advised,
We replaced such rust sections with 1/4 panel patch panels from MILL SUPPLY, Cleveland, OH
(See
https://www.millsupply.com/auto-body-rust-repair-panels/ford/bronco/1979/?page=2
Call them and ask for the gauge thickness.)
They were primed and of 18 gauge steel - exact fit around wheel well arch and packaged very well for shipping.
They also have Upper rear wheel arch area and other 1/4 panel patch panels.
In lieu of welding the panels in-place, consider a quick attachment body adhesive.
Mill sells "Silaprene Adhesive/Sealant, bonds body panels, body seams, roofs. Adhesive will not allow panel to come loose. Used to mount or fasten just about anything together. An adhesive sealant made to last. Actually gets stronger with age, won't brittle or crack from vibration or thermal shock. Withstands extreme temperatures, unaffected by highway chemicals. Used by body manufacturers. Six month shelf life. 10.1 fluid oz. caulk tube, gray in color.
Click here for MSDS sheet" @
https://www.millsupply.com/silaprene-adhesive-sealant-87000.php?p=60
There are other panel sources, but I like Mill.
Here's the 1979 Bronco/F Series Electrical & Vacuum Troubleshooting Manual by Ford via member Ziggy⚠ @
1979 Ford Bronco Wiring Manual pictures, videos, and sounds | SuperMotors.net
It shows Electrical component location, operation, troubleshooting, with wiring and vacuum diagrams.
1979 Ford Bronco Wiring Schematics, Connector Pin-outs, etc by Ranger429 @
79 wiring schematics
1979 Bronco Brochure @
https://www.xr793.com/wp-content/uploads/2020/07/1979-Ford-Bronco.pdf via Dezo's Garage
1979 Ford Bronco vs. Blazer Article by Ford via Indybronco @
1978 Ford Bronco Bronco vs. Blazer (79) pictures, videos, and sounds | SuperMotors.net
Ford Shop Manual Diagrams: 1978-1979 Full Size Shop Manuals, partial @
Technical Diagrams Archives
My Tablet takes hours to download, so try the first in this list as long as you have Adobe Acrobat 9 or later installed.
Includes:
Wiring Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes Rear Lights Diagram
Motor Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes Air Cleaner Diagram
Chassis Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes '78 Brakes Diagram, Gas Tank Setup Diagram
Body Manuals & Diagrams Download PDF This complete manual for the 1972-1979 Ford Bronco Includes; Upper Body Diagram, Front Clip Diagram, heater Ducts Diagram, Tailgate Diagram, Console Diagram, Front Clip Diagram, Grill Setup Diagram, Heater Controls Diagram, Interior Trip Diagram, Rear Sheetmetal Diagram, Tiltwheel Diagram, Tire Rack
Let me know if the downloads are worth the effort.
See
Bubba's M-Block Ford V8 Workshop by Dave Resch
Partial Chilton Manual for 1978, 1979, 1980, 1981 Bronco. Scanned by broncocity.com @
Bronco City
GL!
