Rear leaf spring hanger replacement 96 4X4
kolstee
I have a '96 4X4 Eddie Bauer and I need to replace both of my Rear Leaf Spring Hangers.The rear of the rear springs. Haynes manual doesn't show. Looks like they are riveted to the frame so how do I remove?
Please help. The shackle on the drivers side snapped clean off so I need to fix ASAP as it's not drivable.
Thanks,
John
Drill a hole through the center of each rivet, use a 7/16 bit and redrill the hole half way, then punch the rivet through with a hammer and punch.
the green monster
wisconsin
hey..i just went thru that nitemare myself..i ground off the rivets then welded and bolted in the new ones. About a 3 day process since im still in high school. and big problem i had was getting the old bushings out of the leafspring since i bought new shackles and bushings but all in all its pretty self explanatory
K
kolstee
How did you get the nuts on the backside of the new hanger? Gas tank is in the way.
