Radio Installation
Diane
My 1990 Ford Bronco II needs the radio replaced - it just stopped working. I purchased a new Jensen, but the wires don't match any of the existing wires. There are so many more wires on the new system than the existing radio. Please help - I have taken off the panel and now I can't figure out what to do next. Thanks!!
bart6180
elyria,ohio
go to wal-mart and back by the car stereos you can get a wiring harness for the radio, just connect the jensen to the wires on the harness, and connect the other side directly into the stock radio plugs, yo can also get these at most any store that sells car stereos, sometimes even autozone will have them
MississippiSlim
Your main wires should be Red pwr wire to switched pwr source. Another red or maybe small yellow wire to unswitched pwr source
Black wire for ground
yellow wire usually for pwr antennae (probably wont use this)
blue wire for some accesory (won't need this)
Speaker wires
Usually the wires have little silver tapes on them that say what they are.
or they have a diagram on the box.
Its really simple. If your truck has a harness with a plug you may have to get an adapter install kit
bluesman17
Spam Terminator
South Bend, Indiana
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Front Speakers 4" Doors
Left Front (+) Orange/Green
Left Front (-) Black/White
Right Front (+) White/Green
Right Front (-) Black/White
Rear Speakers 5" x 7" Side Panels
Left Rear (+) Pink/Green
Left Rear (-) Pink/Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/Orange
Good luck :)>-
