CARiD
The aFe Momentum HD Black Cold Air Intake System with Pro Dry S Filter is now available for 2022-2024 Ford Bronco owners looking to add better airflow and performance to their ride. Designed with a high-flow intake tube and a one-piece sealed airbox, this system helps your engine breathe easier by delivering cooler, denser air. The result? Improved throttle response, increased horsepower, and a more efficient combustion process that enhances overall driving performance.
One of the key features of this intake is the Pro Dry S Filter, which is both washable and reusable, saving you money over time while ensuring consistent airflow. The system is designed to keep out hot engine air, thanks to the fully enclosed housing that protects against heat soak. The built-in sight window allows for easy filter inspection without disassembly, making maintenance quick and hassle-free.
Installing this intake system is straightforward, requiring no major modifications. It fits perfectly into the Ford Bronco's factory mounting points and includes all necessary hardware, making it a quick and easy project for most DIY enthusiasts. Plus, with aFe’s reputation for quality performance parts, this intake is a reliable investment for anyone looking to enhance their Bronco’s power and efficiency.
aFe® 50-70109D - Momentum® HD Black Cold Air Intake System with Pro Dry S Gray Filter
Fits: 2022-2024 Ford Bronco
Features:
- Improves airflow to your engine
- Isolates the air filter from engine heat, enabling it to take in cooler, denser air
- Increases horsepower and torque, improves performance
- Designed and tested for each specific application
- Includes a conical high performance aFe air filter
- Comes complete with everything required for installation, including comprehensive instructions
- Can be installed in 30-60 minutes with simple hand tools; no drilling, cutting or fabrication required
- Limited 2-year warranty
- Proudly made in the USA
If you want to learn more about the aFe Power brand, please click the link below:
aFe - About
