Problems with 5.8 removal
84broncorig
I am taking out my 351W from my 84 bronco to put something else, not sure yet. All i have to do yet is to unbolt it from the torque converter, but my problem is i can't get the crank to turn, it looks like the pistons are froze with rust. I have been tryin to use the crank bolt but it screws off on me. What should i do??
swampthing
my best advice to u is to put some trans fluid in the cylinders and let it sit for a couple days then try to break everything loose.....get abig breaker bar and try it.....or if not then just take the whole front clip off and pull the motor and trans as 1 peice....be sure to take the transfer case off and drop the crossmember.....good luck with it
Hello the motor will come off the tranny without unbolting the torque convertor . It will pull right out its just not the prefered method because it will usually mess up the front pump seal in the tranny which is no big deal to replace and it sounds like your redoing the whole thing anyway so it wont be any problem . :D /emoticons/[email protected] 2x" width="20" height="20" />
Shadow_D
Schenectady, NY
I would spray some WD-40 or PB Blaster into the cylinders and let it sit for a few hours or even a day then try it again.
I have heard of people using Coca-Cola to break everything lose as well.
Good Luck
fbrown3
West Virginia
Blade262us has got it I have done it that way many times on engines that have had broken rods and such where you couldn't turn the motor. My 2 cents
84broncorig
hey guys i was able to get it out, i sprayed a cal of PB in there and just cranked the crap outta it. So now it is ready for the 302 for now till i can get my 390 totally rebuilt. Hey quick questoin, I have a C6 in there right now will a 390 bolt right up to that or would it be better to go with a NP435 tranny??
Dallasbronco
20597[/snapback]
Your C6 has a small block bolt pattern: it won't bolt up to the FE.
Wihill
