Problem starting
Plumbers86
Texas
I've got an 86 with the stock fuel inj. 302. It starts fine when cold, but when I start it warm (even after just a short drive), the starter has to crank for a while to get her going. Any thoughts?
broncodave1980
I got the same problem buy some heat shield wrap your exhaust and your starter that might fix the problem
snowman74
Oklahoma
Hate to disagree, but DO NOT wrap any heat shield around your pipes or starter. That stuff creates a breeding ground for rust. You may need a new starter...or solenoid. Get er' checked.
Snowman :)>-
BroncoXLT85
Chelsea, MI
I had the same problem. Replaced the starter and it was fine. Best bet is to get one from Autozone with the lifetime waranty. I did that about 2 years ago and I have replaced it about 12 times. ( starters do not like swimming!!!) You never need a receipt or anything. Great deal if do a lot of off-roading in deep water as any stock starter will bite it after swimming enough.
Ford644
