shawnkelly1970
I have a 91 Ford bronco with 150,000 miles on it that was rode hard before I got it. I have done all the work myself on the engine and it runs so much better now. The problem I am having right now is chasing a height and idle that comes and goes. I have the 5.0 with a five speed and it usually starts and idles just fine. I noticed it when driving around town pulling up to stoplights the idle jump up to 3000 RPM usually. I have to tap on the gas to get it to drop. The frustrating thing is it’s inconsistent. I have done an entire smog delete on the engine. I have replaced all the sensors related to an idle issue. The last being the engine temperature sensor. It ran fine after installing it. Finally finally finally I found the problem or so I thought. The next day the problem was back and my wife got an earful of all the foul language I learned when I worked in the oil field. I have eliminated every vacuum line except for the brake pedal and map sensor. I noticed that when parked in the driveway idling the RPMs will increase when I step on the brake pedal. Also when I first started chasing the problem I removed the throttlebody and cleaned it and Unfortunately I messed with the idle setscrew because of a worn throttle cable. I have read that that is a huge no-no because the computer adjusts the idle from the original position. How do I reset the computer to the new location of the setscrew? Also can the brake power booster have an intermittent vacuum leak causing the issues while driving?
