Power to Manual
Redneck86
First On Race Day
Colorado
Ok so i want to get rid of my power locks and windows. I was wonderin how to do it, and the best way. Door Panels aint a problem, ill order those new from jeffs. What all has to be replaced/taken out to get it done, and where would be the best place to get the stuff.
I think it's much easier and maybe cheaper to just get a set of used doors with the manual locks and glass. That's what I did for my 84 Bronco, using the 88 doors which are manual.
Either do what JSM said or you can change the window regulator, (three rivets to drill out and replace with bolts). They could be retrieved from a junker or you can just get new ones. I believe I have seen them in either Jeff's Bronco Graveyard catalog or in the LMC catalog. The lock can be easily converted by removing the solenoid attached to the linkage.
That was off the top of my head, so I most likely left something out :blink: . The whole point is it's not that big of a job.
crazyhorse85
clarksville,tenn
LIKE SEABRONC & JSM84 WERE SAYING...IT'S NOT ALL THAT HARD A JOB..MOSTLY CHANGING OUT THE REGULATOR ON THE GLASS TO MANUAL AND REMOVE THE LOCK ACTUATOR FOR MANUAL LOCKS...USED OR NEW EITHER WILL WORK JUST WHAT YOU WANT TO PUT IN...LMC HAS NEW REGULATORS FOR ABOUT $50.00 BUCKS...AND YOU CAN GET ALL THE HARDWARE THERE TOO PRETTY REASONABLE....GOOD LUCK DUDE.... B)
