wilcom
I have a problem with my after market power steering. I had it converted from std steering about 25 years ago with a unit from the junk yard and just now bought a new saganaw unit. But before i did i was having a problem with the power steering getting hard to turn (real hard, like almost as if the engine was off) when i take off from a stop it gets real hard to turn while i am winding up to about 4k rpm and shift to 2nd. same thing happens in that gear while winging up to shit to 3 rd gear and so on. While at normal cruse at 30, 45, or 55 mph is it ok, but you can feel it a bit stiff.
When i replaced the old pump with the saganaw the problem is still there.
someone told me that maybe the body frame mounts are bad, loose etc and this could cause the vehicle body to shift on the frame while going forward and winding out the RPM, thus causing the steering shaft to try and strech and then bind up. While they have never been replaced, they look to be ok..meaning not missing or torn.
while ideling or coasting i have no problem.
Any ideas?
Any ideas?
