Power Brakes
mbohnenk
I have a 76 bronco with PB, D44, PS, and disc up front. Question is The brake pedal will not come back up after you push it down. I replaced the master cyilunder and the brake booster, and bleed the brakes. Still the pedal stays down till you pull it back up. The brakes work fine other than that. Is there supposed to be a return spring there of any kind or what? Any Help?
Broncoholics
Broncoholics
Washington State
There is no return spring in brake pedal. I bet the clevis pins are too tight or jambed in there or even fell out. Spray some **** in the joints tap and work the pins so they aren't too tight. Try to tap with a hammer and work stuff until you find the problem.
It also could be paint, powdercoat, binding up. Also check to see if the rod is touching the body.
79' Buckin Bronco
