Possible sabotage?
Cover_Yellow
A buddy of mine interested in my Bronco (5.8L XLT) offered to clean it up for me, and in the process removed the entire interior. That's fine. He moved the truck to my driveway while working on it, and after that it woudln't start. Never had the problem before. All electrical power works, I'm getting spark (checked at the #5 plug) and I'm getting fuel. I checked the emergency shutoff, and it is not tripped. Does anyone have any suggestions as to what might be wrong with it? Thanks.
Does the starter turn the motor over? IF not then I would suspect it or the solenoid went out maybe by coincidence. IF it does crank but not fire, you may need a meter/test light to start checkong any connections that may have been pulled loose. Check all fuses, too.
Maroldeadjub
