Plugs not fireing on my 76 Bronco
kinkle55
I've replaced the plugs, coil, distrib cap and rotor. Im getting power to my coil and starter is cranking but no spark. ***? can anyone help
BroncoJoe19
I would make sure that my coil iwre is fully seated both in the cap, and in the coil. IF not that, I would change my points.
Once they get pitted, you can't set them with a feeler guage.
Are you getting spark from the coil wire to the cap?... Pull the wire from the cap, and hold it close to a good ground while someone cranks the engine.
79' Buckin Bronco
