Please help with electrical problem
Jordanainger47
Completely new. Just bought a 1996 xlt 5.8 auto bronco. Started taking out the crappy aftermarket stereo, speakers, 6 cd changer and amp and went to start it up and no start, with the bonus of the 4x4 light flashing, left tunrsignal indicated staying on and the left turn signal flashing please help me Iam completely lost, thank you
Yo Jordan,
Did you pull just the radio out?
Is the starter cranking engine?
If not:
Wiring Diagram @
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=7214
Check for battery voltage on red/light blue wire on Starter relay,
With key turned to start.
Starter Relay Location pic in a 96
Source: by Roadkill (The Beast)
The starter relay trigger wire (LG/R) comes from the ignition switch via the clutch switch or MLPS and should only be hot with the key in START and either the clutch fully depressed, OR the auto shifter in P or N.
The red/light blue wire goes to the small pull-off terminal @ top of the starter relay.
Starter Relay pic in a 96, on passenger side, near battery
Source: by Shane C. (BigBlue, bigbluebronk) at
.... If the relay fails, bridge between the 2 large studs to send power to the starter solenoid. If the starter still doesn't spin, crawl under the truck with reliable person in cab and ensuring transmission is not shifted and with parking brake on, foot on brake pedal, remove the red plastic cover, and BRIEFLY bridge between the 2 large studs on the starter solenoid (using a heavy metal object with an insulated grip, like a screwdriver) to spin the starter (it won't engage the flywheel or crank the engine). If it still doesn't spin, replace the starter.
Similar threads
T
Replies
Views
1K
Top stories on BroncoZone.com
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
T
Replies
Views
1K
T
felixb52
