please H!E!L!P!
downhillbomer
window stoped working and is in the down postion. checked wires going from tail gate to fire wall had to cut and re conect. but still nothing when trying to roll it up.
took panel off of tail gate and windeow is in the way so i cant get to moter!!
WHAT DO I DO????? [-o<
grande_guerre
grande mondiale
originally-Alaska, temporarily-Arizona
hit the back of the tailgate hard and try again... no, that's just on mine. at the wires leading to the motor, bust out your voltmeter and see if there is voltage going to it when your trying to move it. If not, your problem more toward the battery. If there is voltage, then it's the motor. Good luck.
D
downhillbomer
hay thank you for your help took the hole tail gate off to work on it and see what i could do.. found nothing put it all back togeather and works Great now thank you for your time!!! :D/ :)>-
Similar threads
Maroldeadjub
