Grandpa's-Bronco
- Joined
- Feb 6, 2005
- Messages
- 4
- Reaction score
- 0
I just replaced one of the rear axle seals on my 88 Bronco. The pinion shaft lockpin on the rear differential has a hex head set ***** that holds it in place. My Haynes manual mentions loctite was used on some of these. I didn't notice any loctite when I removed it. It also mentions that some of these pins cannot be re-used. From looking at the pin and set ****** I cannot see why they would not be reusable.
Any further info on this would be helpful. The torque specification is 20-25 ft-lbs for the set ***** (from the Haynes manual). Is it ok just to torque down, or do I need to add loctite as well? I want to make sure my rear differential doesn't fall apart as I am driving.
Thanks,
Christopher Skaggs
Thanks,
Christopher Skaggs
