parts fitment
No.
According to Superlift for thei 4" kits for both years;
for 78-79 Bronco here is their kit w/PNs
http://www.superlift.com/Catalog.asp?P=K485
Part # Description Price Quantity
114 COIL SPRINGS, 66-79 F100/150 4" Call
1275 RADIUS ARM BRKTS., 66-79 FORD Call
2038 BLOCK KIT,3.5", 78-79 BRONCO Call
85140 SUPERIDE SHOCK ABSORBER Call
85280 SUPERIDE SHOCK ABSORBER Call
85300 SUPERIDE SHOCK ABSORBER Call
86010 SHK. BOOT, 2-2.38" DIA., YELLOW
for 85 Bronco;
http://www.superlift.com/Catalog.asp?P=K378
1000 FT. BRKT. KIT, 80-94 F150 Call
1109 PITMAN ARM, 80-94 FORD P/S Call
121 COIL SPRINGS, 80-94 F100/150, BRONCO Call
2197 BLOCK KIT, 2.75", 80-94 BRONCO Call
85270 SUPERIDE SHOCK ABSORBER Call
The 2 shocks can be used.
GL!
G
goinpostal2009
Thanks.
If I had engaged my brain a little sooner I would have answered my own question :( /emoticons/[email protected] 2x" width="20" height="20" />
However I did find a complete Dana 44 and a complete 9" rear (to go under my '85) about 2 1/2 hours from where I live-$450 for the Dana and $200 for the 9". The fella has both of these under his '87 for now. So would this be a good deal? And just how much work to change the front and rear out?
No.
for 85 Bronco;
GL!
I think it's a good deal, depending of course, on the condition of both.
78 Dana 44 with radius arms and brackets - usually $200 - $400
For the DANA SAS see many links for the swap in my site under;
SUSPENSION;
Solid Axle Suspension (SAS
@ http://www.broncolinks.com/index.php?index=359
& other SAS Costs depending on other Mods;
25.00 Radius arm caps with out shock mount (2)
135.00 78 6" Super Lift springs
32.00 7 Degree "C" bushings
18.00 Radius arm bushings
320.00 RS 9000 X shocks (4)
30.00 ProComp steering stablizer
36.00 Beard limiting straps (2)
30.00 78 upper spring buckets
30.00 78 lower spring buckets
25.00 Spindle studs (10)
60.00 Misc. hardware
44.00 F250 upper shock mounts (4)
110.00 Chebby tie rod and drag link ends (2 & 2)
10.00 Jam nuts for Chebby tie rod ends (2)
100.00 D.O.M. tube for tie rod and drag link
40.00 Axle U-joints (2)
42.00 Upper ball joints (2)
41.00 Lower ball joints (2)
60.00 Inner & outer wheel bearings (2 & 2)
10.00 Wheel bearing seals (2)
64.00 Loaded caliper (2)
62.00 Rotor with hub & lugs (2)
10.00 Break hardware kit
50.00 D.O.M. tube for track bar and brace
180.00 Heim joints for track bar and brace (4)
20.00 Steel used for track bar mount and brace
50.00 Paint, oil, RTV, grease, ect.
160.00 4.56:1 Gears
90.00 Master install kit
50.00 Pinion yoke and U-bolts
55.00 3.92:1 and up empty carrier
22.00 Drive line U joint
30.00 Cosmo & Cam alignment shims
50.00 “Pro” done alignment
& Some other SAS Info;
Reused TTB parts
·Dropped pitman arm
·Warn Hubs
·Extended break line (fabbed new retaining brackets)
·LockRight
·PowerTrax cross shaft
Special tools needed
·7 degree tapered reamer ($65.00)
·7/8" 18 pitch right hand tap ($78.00)
·7/8" 18 pitch left hand tap ($148.00)
·3/4" 16 pitch left hand tap ($95.00)
Tools used to do the job
·Air tools (1/2" impact gun, 3/8" wrench, 90 degree drill, cut off wheel, die grinder, air hammer)
·Electric tools (3/8" & 1/2" drill, grinder, saw-zal, bench grinder, drill press)
·Shop tools (20 ton press, vise, anvil, jacks, jack stands)
·Metal working tools (lathe, MillerMatic 210, Oxy torch)
·Hand tools (all the standard stuff, Dana 44 hub tool, tap & die set, good set of drill bits and a bit sharpener)
Estimated hours to complete work
10 Gathering of parts (over 2 weeks)
8 Cleaning and painting of parts
5 Complete rebuild of axle
2 Build steering and track bar
4 Fabrication
6 Remove TTB, front suspension & prep frame (2 people)
4 Install spring buckets, radius arm brackets, shock mounts & track bar bracket
4 Install axle, break lines, shocks, steering & drive line (2 people)
2 On road testing and tweaking
45 Total Man Hours
by Dustin J (SOLD, rokhrse, sukngas) & Scott S (Canyonaro, dogonmut) & Mike W
9"
see my site @ http://www.broncolinks.com/index.php?index=98
see
Installation w/4.56 in an 89 5.8 (SOLD, but Brian is keeping his info available
Source: by Brian S
included in there is a hot Link to Brian's Dana 44 swap
GL!
Ford644
