oxygen sensor location
51504broncos
Just wanted to confirm the correct location of an O2 Sensor on my 96 Bronco 5.8L.....I am replacing the Bank 2 Sensor 1 sensor. I believe this is the sensor on the drivers side first one from the block...am I correct?
Thanks.....Bryan
yo Bryan,
You are correct.
Location Pic in a 96; Bank 2, driver's side;
Bank 2 is the driver's side.
Bank 1 will always be the bank containing the #1 cylinder (Passenger Side in our Broncos).
Sensor 1 is da upstream sensor, between the engine & the catalytic converter.
miesk5 Note, the 2nd is on passenger side; the 3rd is between the converters and Calif Models have a 4th behind rear converter
Identification & Location in a 96 5.0 & 5.8
Source: by miesk5 at Ford Bronco Zone Forums
http://broncozone.com/topic/15022-o2-sensor-question/page__st__20__start__20
51504broncos
yo Bryan,
You are correct.
51504broncos
yo Bryan,
You are correct.
Miesk5,
Thanks for the help and the very clear visual example.
Bryan
Gasman80
