Original Ground Clearance
lh4882
Illinois
I need to replace my bushings on my radius arms. I figured I would replace the C-Bushings while I was at it. Some of the options have different degrees for if there is a lift. Ok so here is my dumb question what is the original ground clearance for a 1970 Bronco or how can you tell if there has been a lift? I'm guessing there is no lift but I honestly have no clue. :unsure:
No dumb questions.... :-B
From the ground up, at the door, to the bottom of the rocker panel is 20" on my rig WITH a 2.5" lift.
If yours is stock., you will measure approx, 17"-18" +-
Also if your C-bushings are "rubber" not poly.., they're likely orig. especially if they're cracked/nasty looking.
L
lh4882
Illinois
Well they are cracked and look as though they are about to fall apart. Thanks for the help
stevedave
