oil sending unit
jaszon
rhode island
was wondering if anyone can tell me where the oil sendind unit is located on a 5.0 ltr motor. my 95 bronco has two bad gauges and i want to replace them with after market ones but im not sure where the hook up for the oil pressure is.i found the water temp and replaced it with a new temp sensor but the gauge in the dash still doesnt read,any help will be greatly appreciated. thanks again
J
jaszon
rhode island
i tried the search feature and another webpage and still cant seem to locate the sending unit on the block, can someone please point me in the right direction. i would really like to install these new gauges then take care of the other little things,thanks again
The oil pressure sending unit is located behind the powersteering pump . should look like a bell shaped thing with a wire conected to the top. When you replaced the coolant sensor did antifreeze come out of the hole ? I ask because the incoming air temp sensor is very close to the coolant sensor and you may have replaced the wrong one . :D /emoticons/[email protected] 2x" width="20" height="20" />
J
jaszon
rhode island
18027[/snapback]
thanks blade this will help alot,ive been laying under my truck for 2 hrs trying to figure this out,in regards to the temo sensor the answer is yes antifreeze did come out but the gauge still isnt right so i figured id replace all of them,would you know why my truck shakes between 60 and 70 mph,i figure its a unbalaced wheel,thats where im going to start then im replacing the oxygen sensor because the truck seems to be running sluggish after i just did a tune up of plugs etc.. thanks again for the info
The vibration could be worn radius arm bushuings,worn ball joints,tires that are worn funny, or unbalanced wheels . Thats where id start . :D /emoticons/[email protected] 2x" width="20" height="20" />
Wihill
