oem or aftermarket bodyparts?
gungho
I need to replace the hood, and both front quarterpanels. After looking around for a while i found that broncograveyards.com has aftermarket quarterpanels for $85 and hoods for $130. The oem hood is $400, and the quarter panels are $420. That is a big price difference, which one should i use?
Shadow_D
Schenectady, NY
Welcome to the Zone! >
Well I guess the best answer to your question is to ask how much can you afford and how good are you at fighting and aligning parts?
The OEM parts will line up easier then aftermarket. If you don't mind working the parts then go for the aftermarket parts, but if you don't want that hassle or you are having a shop do the work then spend the extra $ and get the OEM.
I hope this helps.
Wihill
