Buschboxer
I am having some problems. It feels like cats are plugged but they aren't, any other ideas for this type of loss of power?
Last month you posted that you thought that you had a bad transmission.I am having some problems. It feels like cats are plugged but they aren't, any other ideas for this type of loss of power?
Last month you posted that you thought that you had a bad transmission.Did you get that ruled out?
This post really gives us nothing to work with.
When was the last time it had a tune up?
Does it stall or throw any codes?
As BroncoBill78 asked was the loss sudden, or gradual?
Does it idle well?
Is it hard to start?
Did you do a compression test? Your timing chain could have jumped a tooth.
We'll try to help, but you gotta give us something to work with.
Right off the top of my a$$ it sounds more like an induction issue. Best advise I can hand out is to follow Miesk's advise and let us know what the results are. With more info everyone here can probably help you narrow it down. Chances are you're looking at a cascade failure and that's causing the problem but hey, what do I know <grin>. Follow up on what Miesk had to say & let us know.
Give that TV adj another shot; TV Linkage Adjustment Source: by Baumann Electronic Controls, LLC becontrols.com http://www.becontrols.com/tech/tvlinkage.htm
read both w/ and w/out gauge
