NO SPARK
Krafty
Ontario Canada
alright 89 f 150 302 efi 4x4
new coil, new ignition control module
new cap rotor plugs, wires
ran through all the tests in Hynes to no avail
I need this truck running and certified before the end of the month
50joe
Trenton NJ
Is the distributor even spinning? Have seen the roll pin in the gear shear off......
Krafty
Krafty
Ontario Canada
no the gear on the distributor is still on and it does turn when spinning the engine over.
I have been having symptom 3 all along. and I have gone through all of the tests for every component step by step. none of them have shown any faults. I have checked the continuity of every wire. it has all cleared. the only part that is original is the eec.
and im not getting any codes
Krafty
Krafty
Ontario Canada
step 75 says. "Inspect the base casting for cracks and wear. If any damage is evident, replace the distributor assembly."
I took a distributor and stator assembly out of a truck at the scrap yard that was running when it got there. no change.
Krafty
Krafty
Ontario Canada
but I have gotten two new ICM's and put them in correctly and each of them still comes up with the same result
Krafty
Krafty
Ontario Canada
yes it does, and no you can't do it by hand. and i've had the distributor out a couple of times and everything is in good working order
Bronc76
Just by chance, have you checked to see if you have any broken wires in starting circuit?
Krafty
Krafty
Ontario Canada
no ther were no broken wires. I had the whole wiring harness from the computer to the engine checked, Turns out that the computer was starting to go, and it in turn was making alot of other systems not function properly.
its got a different computer in it now, it sparks, and even starts like new again.
before when it had spark it was very picky about when it wanted to start and run.
I'm waiting for it to come back from the safety, all it needs now is a muffler and a tailpipe
wow, last thAng to suspect or have to replace !
I just found this TFI Troubleshooting Article after months of searching for it in my back-up files; http://www.therangerstation.com/tech_libra...Diagnostic.html
Almost all applies to Big Broncos & any TFI Ford.
I need to confirm all TS Steps & ensure they apply to our Biggies' 5.0 & 5.8 as well as da 4.9 torquer.
They use the Grey TFI Module in their testing (at bottom). Have to log off due to severe T Storms and power outages now.
Krafty
Krafty
Ontario Canada
lol thanks, little late this time, but I will save it in case I ever run into that problem again.
Motormouth2025
