Fisherleep
- Joined
- Sep 16, 2004
- Messages
- 11
- Reaction score
- 0
I have been narrowing down a starting problem for the past few weeks and have gotten it to the coil. I have a 75, I bought a good used harness, new coil, new distibutor, ignition module, starter relay, carb. All of the dash compenents are not hooked up but I figured that this would not effect the spark. The engine turns over fine, I am getting 12v out the ingition module, and 12v into the + side of the coil and ~6v into the - side. However I get 12v out of the coil when it is in the key "on" position, with the key to "start" I get 12v also. I have tried multiple ingnition modules b/c I understand they go out quickly. Does anyone know from a schematic or by testing theirs what voltage is suppose to be coming into the coil during these key positions? If the 12v and 6v is correct, what else could be causing the coil to not send the correct voltage to the distributor? What else is the coil dependent upon besides those two (+/-) wires? Thanks.
