Battery Static & Load Test, general; "...Static testing : With a good digital voltmeter check the static voltage. If it is above 12.6 remove the surface charge by operating the headlights for 15 to 30 seconds and then recheck. A reading of 12.6 or higher indicates a full charge. A reading of 12.4 indicates 25% discharge. A reading of 12.2 indicated 50% discharge. A reading of 12.0 indicates 75% discharge. A reading lower that 12 .0 indicates almost complete discharge..."
Source: by excelauto.com
Or pull batty and have it load tested for free somewhere.
because I've seen more owners with this problem due to a:
Dead Cell; "... Sometimes, a battery will have just one cell go bad or short out. When this happens, the battery will seem fully charged, but fail to start the car, or it may start the car right after charging, but then fail to start the car an hour or more later. If this happens measure the S.G. in each cell. If one cell has a lower S.G. than the rest by a significant amount, replace the battery - there is no way to fix this problem. This condition most often happens to batteries subjected to lots of vibration, and sometimes to new and almost new batteries that have a bad cell from the factory..."
Source: by Gordon via miesk5
It got to me last year.. I did all kinds of tests and couldn't fig out what it was until I recalled the old dead cell issue... I think a lot of batty mfgrs are losing quality ctrl.
Next is to ck all batty cable and grongs from batty to engine, fender apron, etc. Look for corrosion on posts/terminal and wire strands (see if there is any where wire strands meets terminal) under terminals
Ck for 12v @ starter relay large cable from batty
and then... look at fusible links last
Wiring Diagram in 92-95 Bronco & F Series
Source: by Steve83 (Steve, That dirty old truck) at SuperMotors.net
