JBronco
I have an 88 Bronco and it left me sitting a week ago and I figured out that it was a problem with fuel pump right away because when i went to try to start it I couldnt hear the fuel pump winning like usual. So i had it towed home and started troubleshooting i hooked a battery to both fuel pumps and they both worked i checked all my fuses they were all good just when i turn the key to run pos the pump doent come on and no fuel gets to engine i am completly stumped I did change a relay that at the time i though was the fuel relay but im not sure now i changed the relay that mounts to the inside of the fender on the drivers side but there are 2 other relays on the top of fender that look the same im not positive what relay is actually the fuel pump relay byt i did change the one mounted to inside of fender any help would be great thats for listening
