nitrous
gregor
gregor
pope afb north carolina
I was wondering if anyone has tried to put a nitrous kit on there bronco. I am currently rebuilding my 302 and thought that it might be a nice addition to it. Any input would be greatly appreiciated.
If your building the motor and have it apart now I would get some ARP rod bolts and you must add around 20% to the ring gap . Also motorsport makes a severe service head gasket kit for the 5.0 jegs has it as part number 397-M-6051-A50 $114.99 and you should drop the heat range of your spark plugs a couple levels . :D /emoticons/[email protected] 2x" width="20" height="20" /> Oh and one more thing you have to ****** your timing 4 degrees per hundred horse so you may want to look into an MSD ignition system .
Wihill
