newby
Kegger
hello, here in central texas, had my bronc 74 for about 7 years now 74 95,efi disc brake up front 4:11 f/r, surperior axles 31 spline mm lockers jd, J shifter, 2" lift 31 micky t claws/ mt rims, custom 6 pt roll,stock front seats, diamond plate the dash and rear panels sandlewood paint bushwacker gloss black flares c-4, duff alum radiator. its never done theres allways some improvment, next, anybody done the elec wiper w/intermitit switch?? yet, don't sweet the spellin' I wont tell. maybe some pics will come if I can figue it out. still the hunting season shes dirty. also thinkin' of engine re do got the hole thing for 50.00 $$, thinkin 331 stroker?? 95 ecu ? speed density system. led the lights and the head light up grade. the motor needs enough vacume for the brakes?? cam selection gots to be right, or the ford racing 306 with the x heads but Iam not sure the b.c. bronco headers will go up to it?? any way hi.
Welcome to the Zone > If you use full editor, it will have a browse function. If you click on that, it will let you browse the files on your computer and allow you to select what you want to share. Please keep the pictures down to around 1024 x 768 maximum, otherwise they will take for ever to load by members with low speed lines.
Oldhenry1
