yo Rob
WELCOME!
Consider better gauges for Oil Pressure (stock gauge Sender is merely an on-off switch);
Fake Oil Pressure Gauge TSB 88-05-14 for 87-88 Bronco & F Series
ISSUE: An oil pressure gauge that indicates an erratic or low reading when the engine oil pressure is within specification may be caused by the oil pressure sender. The oil pressure sender may not work properly with the magnetic oil pressure gauge.
ACTION: To correct this, install a new design oil pressure sender and new design resistor wire assembly using the following service procedure. Refer to the oil pressure sender and resistor wire application chart for the correct service parts.
OIL PRESSURE SENDER AND RESISTOR WIRE APPLICATION CHART
Engine Application Description Service Part No.
5.0L, 5.8L, 7.3L and 7.5L Oil Pressure Sender E6SZ-9278-A
4.9L Oil Pressure Sender E8TZ-9278-A
All Resistor Wire Assembly E6SZ-9F291-A
SERVICE PROCEDURE
1. Remove the existing oil pressure sender.
2. Install the new design oil pressure sender. Torque oil pressure sender to 10-18 lbs-ft (13-34 N-m).
3. Connect the female terminal end of the 20 ohm resister wire assembly to the oil pressure sender.
4. Connect the male terminal end of the 20 ohm resistor wire assembly to the vehicle wire harness.
PART NUMBER PART NAME
E6SZ-9278-A Oil Pressure Sender
E8TZ-9278-A Oil Pressure Sender
E6SZ-9F291-A Resistor Wire Assembly
OPERATION DESCRIPTION TIME
880514A 0.4 Hours.
See this done in Oil Pressure Mod to Actual PSI "...short R in PCB..." in 87-88 F series trucks and Broncos
Source: by Mike & Debbie at
http://www.rowand.net/Shop/Tech/FordOilPressureGaugeFix.htm
or add a real gauge w/Numbers; Installation, Sunpro Mechanical, w/T for stock gauge in an 86
Source: by Sixlitre (Malcolm H, Eddie Bauer) at
http://www.supermotors.net/registry/4970/22156
More LINKs in my site @
http://www.broncolinks.com/index.php?index=949
and maybe tranny temp (can tap a port on tranny), such as:
tranny temp Gauge & Sending Unit Installation in an 86 AOD
http://www.supermotors.net/clubs/superford/registry/4970/17326
Sensor Location in an 88 (into the rear tranny line port (input)
Source: by Dustin S (Dustball, Mellow Yellow, Mr. Laser Boy) at
http://ylobronc.users.superford.org/460/c6tempsendervent_JPG.html
http://www.broncolinks.com/index.php?index=645
Tranny Cooler is a good off road option; as well as a DD
see some Install LINKs @
for an AOD;
http://www.broncolinks.com/index.php?index=59
for a C6 @
http://www.broncolinks.com/index.php?index=786
Suspesion Lift?
http://www.broncolinks.com/index.php?index=351
Solid Axle Suspension (SAS) Conversion
http://www.broncolinks.com/index.php?index=359
and, Jeff at the Bronco Graveyard (Our Sponsor here) has offered a 2% discount to members of The BroncoZone for on line orders. To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
http://broncograveyard.com
