meatheadz
ok, 2 new problems to add to the list
1) when ever it rains my driver side carpet is wet under the floor-mat, no water on the mat. I think it is coming in through the door somewhere. Could bad window moldings be causing this? Cuz I need some new ones. other than that I have no idea where it could be leaking.
2) Sometimes when I brake the ABS engages and the light comes on. If I continue to drive it usually does not happen again. If I restart the engine the light goes off and it usually continues to drive ok. It scares me to death though when I try to stop and I continue moving forward with the ABS going off, especially when It happens at a stop light. This happens on totally dry pavement. Is this brake fade? Need to figure this one out pretty bad.
thanks all.
thanks all.
