New guy from Hickory,NC
Ashley
Hickory,NC
I have a 88 bronco 2 that my wife owned before we got married . Finnaly after all the other projects i'm starting on the Bronco . Been setting for awhile . Drove it a few times in the snow ,the clear coat was falling off and had some rust  ,tires dry rotted , valve cover leaking , etc . Decided to camo it and it turned out pretty good . New tires  the end of month . Radiator flush , oil change , brake fluid change , fuel filter . new radio , seat covers ,front grill ,found a rear tube bumper in OH still in ford wrapping ( I WAS LUCKY ). She is running great ! The temp gauge is not working . Hope it is the sending unit . Going to test it this evening . Thanks for letting me join the club ! LOVE THIS LITTLE TANK !!Bronco 006.jpg
yo Ashley,
WELCOME!
Most Bronco & Bronco II Engine Coolant Temperature Gauges & Senders are similar;
Pull the R/Wh wire straight off the sender & ground it to the block, intake, or head. Then turn the key to RUN. If the needle pegs, replace the sender. If not, diagnose the circuit.
Ashley
Ashley
Hickory,NC
Thanks for the welcome . I had seen that on a previous post about how to tes . Thats why i joined . Figure if i have any questions this is the place for answers .
Oldhenry1
