WileE7
- Joined
- Apr 12, 2006
- Messages
- 105
- Reaction score
- 1
Hello I have a 1990 Bronco. The original transmission was an AOD. It has a C6 transmission I needed to use a switch to start it and the gear selector was slightly off I needed to put it in neutral to put in reverse drive for neutral etc. I just had the transmission rebuilt and when I installed it my friend disconnected the switch and I was able to start the truck with the key. I adjusted the gear selector and know it won't start with the key. I can start it with a screwdriver in the starter solenoid and nothing with the key. Any thoughts or suggestions? Could I bypass the neutral switch
