Need Help!
MudGoneWild
I bought the truck not running and so far I have changed: the distributor, coil, both fuel pumps, fuel filter, water pump. The truck still wont start and it doesnt have power goin to the fuel pumps at all and the spark to the plugs is there but not constant. Thanks for the help.
M
MudGoneWild
Oh yea and the kid i got it from said it ran before he changed the steering column. I was thinking it might be the computer got shorted out but I wanted to see what you all thought before I go spending any more money. Thanks.
M
MudGoneWild
I think the inertia switch is fine. When I took it off it was still pressed down but something shakes inside so I don't know if that is normal. Any other suggestions??
Get a meter and check the voltage on either side of the switch. That will tell you if it is OK.
Ford644
