Jake69Bronco
Hello All,
As I said in my intro I'm new to the Bronco world and am looking for some help! First my '69 has a steering problem where anything above 30 mph it feels like I am going to lose control and takes constant correction to maintain a straight path. While stationary it takes about 4" of movement on the steering wheel before the tires begin to move. I've attached pictures of the lower steering column down to what I think is the steering box. Also the previous owner added what looks like a power steering (pic also attached) as it does not look factory and he has a power steering cooler coming off it with a fuel line running through the top loop...I may be way off as I'm not a mechanic so if I miss identify something or call it by the wrong name please correct me so I can learn! I'm looking to replace/fix what I can without taking it to a shop so any advice is great.
I have also attached a picture of my rear fuel tank (looking back at it) as there is a leak from what I think is the sending unit? Any advice on how to fix that would be great as my wife and kids keep telling me my truck stinks.
And finally a couple pictures of the transmission from below as there is a leak there also I'm hoping just from a gasket? And one from the left axle/brake area that is soaked in fluid but I can't see where it is coming from so I'm guessing its brake fluid.
Thanks for your time!
Jake
Jake
