Yo Jeff,
if you have a 95;
Fuel Gauge;
Testing & Connector Pin-Outs in 92-96 Bronco; Sender Range: Full = 160 Ohms; Empty = 16 Ohms; "...
gauge that pegs past full indicates an open circuit (broken wire; unplugged connector; corroded terminal; burned sender) on the Y/W wire. gauge that pegs past empty indicates a short to ground (pinched to the frame, body, or dash supports) on the Y/W wire, OR a sunk float. gauge anywhere in between that doesn't move indicates an open circuit (blown fuse; corroded terminal) on the power (battery) side of the gauge OR a bad instrument cluster ground at C251 pin 9. The terminals of C251 (& C250) are known to corrode & lose contact. Polish both the connector pins AND the film circuit pads with brown paper or a pink eraser. The larger version of C441(WPT454) was used until 93. The level sender can usually be disassembled & repaired by bending the wiper arm inside the plastic housing to apply slightly more force..."
Coolant Temperature Gauge
Check gauge calibration as follows:
- Using a Rotunda Instrument Gauge System Tester 014-R1063 or equivalent, with the key in the OFF position, disconnect wiring connector at the sender and connect tester to wiring connector.
- Set the tester to 74 ohms.
- Turn the key to RUN, and wait 60 seconds. The gauge should indicate on the COLD graduation.
- Set the tester to 9.7 ohms and wait 60 seconds. The gauge should indicate on the HOT graduation.
- If engine coolant temperature gauge tests within calibration, replace engine coolant temperature sender.
- If engine coolant temperature gauge still tests out of calibration, replace coolant temperature gauge.
Oil Pressure Sender
Check gauge operation as follows:
- With the key in RUN and the engine off, disconnect wiring connector at the switch. The gauge should indicate on the LOW graduation or below.
- Connect the wiring connector to the engine block ground. The gauge should indicate just slightly above mid-scale.
- If the oil pressure gauge tests within calibration, replace oil pressure switch.
- If the gauge still tests out of calibration, replace oil pressure gauge.
Battery Voltage Gauge
Test the battery voltage gauge as follows:
- Turn the key to RUN, turn the headlamps on, and set the heater blower/fan on high with the engine (6007) stopped. The gauge pointer should move toward the lower portion of the normal band (the white marked area).
- If no movement of needle is observed, check the fuse and the battery-to-circuit breaker and circuit breaker-to-cluster wire connections.
- If connections are tight and wire continuity is good, remove the instrument cluster (10849) from the vehicle.
- Check for flex circuit continuity and confirm flex circuit-to-clip and clip-to-gauge contact.
- If all connections are good, replace the instrument cluster.
