mustang 302 parts on bronco 302?
daniel302
New Orleans, Louisiana
here's the deal, i have a complete intake manifold and throttle body from an 80's or 90's mustang gt 5.0 302 EFI, i was wondering if i could swap that intake manifold and throttle body for the one on my 93 bronco 302 EFI with the stock heads? has anyone done anything like this?
ole betsy
st. peters MO
works with no problem. youll have to get a different egr valve.
Works with problems. The mustang uses a different firing order, therefore all the injectors will open at the wrong time for your Bronco, use the Bronco injector's harness and you should be OK. Also I am unsure how your throttle linkage and TV cable will fit. Might be different
