Missing part...
nenyegirr
I just got my 1987 Ford Bronco a couple of months ago and have been working on it myself.  As I was examining things under the hood the other day looking for my coolant temperature sensor I noticed that I have a metal hose that comes from the radiator that is not attached to anything, there is a piece that holds that hose to another metal hose that is also not attached to anything.  My family thinks it may be the a/c unit missing but I am having trouble finding any labeled diagrams for my year of bronco.  Any ideas from anyone would be great.  Also the hoses are not capped so I think that is where I have been losing coolant but not exactly sure.  Thanks in advance for any help.  I will upload some pictures as soon as I get the chance as well.
Yo nenyegirr,
Throttle Body Coolant Line From Radiator Splice Video in an 86 5.0
Source: by JKossarides ("The Bronco", Jean), click to see
pics in a 90; "...An Agriculture Supply shop that builds custom crop sprayers had high temp plastic. One 1/2 inch T and one 1/2" to 3/8" coupler, new hoses, and new clamps..."click to see
Source: by Supersanbob (Super Bronco)
Throttle Body Coolant Line & By-pass reducer & Tee (one leg runs to throttle body); "...Some V engines also have a bypass hose which allows coolant to return directly to the water pump. There may also be a small circuit to the throttle body for de-icing, which typically returns to the radiator upper tank...."
http://www.supermotors.net/registry/media/624513_1
Throttle Body Coolant Line From Radiator; "...Top hose goes to the filler neck, bottom is the coolant source from the metal fitting that screws into the intake manifold (look where the heater hose and ECT sensor go, there's a 3/8-inch ****** on it)..."
Source: by SigEpBlue (Steve)
Next time, please fill out your Signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses.
Click your name in right black panel in upper right;
In pop up,
Click, My Profile
Click, Edit My Profile in right side black panel
In left panel, Click, Edit Signature
Enter info
Click, Save Changes
To post a pic from your PC, TABLET, etc., just below the reply box in lower right corner, click More Reply Options
Screen will change
See Attach files
pick out the pic
Click Attach This File
or click, Try our advanced uploader (requires Flash 9)
Keep each post limited to one issue.
Our sponsor, Jeff at the Bronco Graveyard has offered a 2% discount to members of The BroncoZone for on line ordersTo get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
http://broncograveyard.com
Here are some wiring diagrams (partial, 86 through 96) and Technical Service Bulletins, (80 through 96) @
Wihill
