Mirrors
astronot
Central Texas
Seems too quiet here so ...
Did EBs come with rear view mirrors? My 74 has one on the drivers side door and nothing else. Cant' even see mounting holes for one on the upper WS frame. I'm think of getting one of the glue on kind for the WS.
Yep., what you have (door)is prob. stock. They're small., close-in & work well.
(You can get a matching one for the pass. side.)
Beings these W/S's are so short.., gluing on the glass blocks your view.
I made a triangular bracket & pop-rivited it to the upper frame...drilled a hole & mounted the RV mirror to it. It still adj. up & down, etc. & I can see under it.
The glue pops loose here in the desert quite often.
astronot
astronot
Central Texas
Yikes! It gets pretty hot here in TX Hill Country but not like in the desert. I think I can find a place on the WS frame to get it mounted. Just never could figure out if they came without them or what.
Thanks!
79' Buckin Bronco
