measurement for back seat bolts
jats
anybody know the measurement for the back seat bolt holes,on a 74 bronco, Had the inside sprayed, but they did not protect the bolt holes for the back seat. I'am tired of poking around... Thanks.. jats
Lyle
Lakewood Colorado
You may be able to see a couple of the welded nuts from the bottom, then push an awl through the hole. Once you find one or two, just measure your seat mounts and it should be fairly easy to find the rest. They will probably clean out with a tap of the correct thread. You will also have seat belt holes back there too. Dont be tricked.
J
jats
thanks, I figured it out I guess I had one of those moments.
79' Buckin Bronco
