You can get anything to work ... with a little help.
Here is my stock height 1993 Bronco with 35" BFG mud terrains crammed under her. The back is fine and I put about 200 miles on her with the 35" tires in the rear. The front is very tight ... and required trimming the front bumper ... and I still had a rub at full turn. It rubbed on the plastic splash guard.
The spring are stock ...... so they sagged at least a few inches. If you replace the springs and trim the bumper you should be able to stuff the 35" under her ... but I wouldn't try to beat on her too much. You just don't have the flex.
33" tires should fit all day long with a stock ride height.
