Map Light Bulbs??
Otto Rex
I have a 95 Eddie Bauer Bronco with the overhead console. The map lights were missing when I bought it and its a pain without them (dome light does not work). Can anyone tell me what bulbs I need to buy? My local parts store says it need either a 912 or a 561 and neither one fits in the housing.
yo Otto,
We have a problem my man; my 96's Owner's Guide shows 561-105 bulbs for "Dome/Map" Combination in that exact phrase
O
Otto Rex
Do you know if there are different styles for 561's? I have been trying to find an image of a bulb installed in the housing, no luck so far. I may be missing some hardware to hold them in.
yo O
I think Owner's Guide means its a # 105 Miniature Lamp for the MAP portion of the combo MAP/Dome light
Voltage Rating 12.8 Volts - Trade Lamp Number 105 - Power Rating 1.00A - Lamp Description Auto Interior - Candle Power 12.00 Candelas - Rated Average Life 500 Hours - Base Single Contact Bayonet - Bulb B-6
if Image does not appear see it @ http://www.google.com/products/catalog?q=105+bulbs&rls=com.microsoft:en-us:IE-SearchBox&oe=&rlz=1I7ADFA_en&um=1&ie=UTF-8&cid=11089507349954358669&ei=TK0OTf-eJ4WClAeBgM3QDA&sa=X&oi=product_catalog_result&ct=result&resnum=3&ved=0CCkQ8wIwAg#
O
Otto Rex
That makes a bit more sense. I'll try one of those Monday.
O
Otto Rex
Found a pic of the parts I am missing. They are plastic caps that hold the bulb into place. Know where I can get a set?
Finally the little brain floater popped and I 'membered w/so many foklks have asked same Q, in different manners over da years;
Erratic Compass & Map Lamp Operation TSB 96-8-15 in 94-96 Source: by miesk5 at Ford Bronco Zone Forums
TSB 96-8-15 Erratic Compass & Map Lamp Operation - Vehicles Built Through 2/1/96
Publication Date: APRIL 8, 1996
LIGHT TRUCK:
1993-96 EXPLORER
1994-96 BRONCO
ISSUE: Map lamp switch and/or overhead compass function operation is irregular, and/or map lamp bulbs may burn out on some vehicles. Installation of revised parts should resolve this issue.
ACTION: Replace the map lamp, switch, compass and wiring harness with a revised Overhead Console Kit (F67Z-78519C42-AA). Refer to Instruction Sheet #7151, included with the kit, for service procedure.
The Overhead Console Kit (F67Z-78519C42-AA) includes the following:
One (1) Map Lamp Assembly
One (1) Map Lamp Button
One (1) Compass
One (1) Wiring Harness
One (1) Modification Label
One (1) Instruction Sheet (I.S. #7151)
PART NUMBER PART NAME
F67Z-78519C42-AA Overhead Console Kit
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION DESCRIPTION TIME
960815A Replace Map Lamp And Console Assembly 0.3 Hr
Rear Counter is a good Ford parts finder - other than calling a local dealer;F67Z78519C42AAPart:F67Z78519C42AAAvailability:
7 found at 1 dealer Price: Please Inquire
Condition:New OEM Seller Location: Cincinnati, OH - Call Seller - (513) 294-8385
Description: KIT CONSOLE ROOFClick Here to Order This PartThis part was found at a dealership that is authorized to sell the following brands: Ford
Maybe local dealer can find the assy for you instead of the entire kit; one gave me a parts break-out diagram years ago for the console, but that was trashed during a move.
Explorer consoles appear to have same map light assy
So a yard search may be needed.
LIGHT TRUCK:
1993-96 EXPLORER
1994-96 BRONCO
One (1) Compass
I have the same assembly as Otto Rex in my overhead console, are you saying that there is a replacement assembly for that? Are you saying they don't make the bulbs for that any more?
It is a small cylinder shaped bulb with a cone shaped contact on each end.
yo Fred,
No, I was giving him the next higher assembly (One (1) Map Lamp Assembly) for the "plastic caps"
In a prev reply here, I told him; # 105 Miniature Lamp for the MAP portion of the combo MAP/Dome light
He'll prob want to get the kit anyway since the TSB did come about due to "overhead compass function operation is irregular, and/or map lamp bulbs may burn"
In the past, others have asked why their dome light portion had erratic lighting. They usually pulled both map and dome light bulbs out to stop them from flickering when used and also to stop em from affecting the compass
o you have the 92-96 overhead console in there Fred?
Yah, I added it while I was doing my body metal repairs in the past year and a half. I'll have to look at that TSB. I only had it happen once, but the whole display was going nuts then it quit and hasn't happened since. I looked at the bulb by the way, the only markings on it were "A12V10W" 12 volt 10 watt, in case someone needs to replace a bad one.
OK, DUH!!! That is the service bulletin :blush: :blush:
yo Fred & Otto,
ok, thanks Fred.
It is prob the 561 bulb as you described..."It is a small cylinder shaped bulb with a cone shaped contact on each end..."
GE 561 Image @ Rock Auto = http://www.rockauto.com/catalog/moreinfo.php?pk=2548284
grainger.com
Lamp,12.8 V,561,Pk2Item # 3BA99Miniature Lamp, Trade Number 561, T3 Lamp Shape, Rigid Loop Lamp Base, Primary Application Automotive, Voltage 12.8, 12.4 Amps/Watts
Image @ http://images.grainger.com/B322_21/images/products/250x250/Miniature-Lamp-3BA79_AS01.JPG
to get an assy;
http://www.mypartshop.com
Select All Parts
year, etc, then FORD TRUCK
Saw 3 pages of hits for your zip (I went back and saw your post about your zip)
First 3 hits.95
BRONCO Console
RED GOOD 0 S01393
27381 0.0 Call 88 Call Florida Auto Parts, Inc.
518-843-2498
800-858-8744
Louis
518-843-2498
800-858-8744
5915 State Hwy 30
Amsterdam NY 12010
www.florida-part.com
95
BRONCO Console
TAN COL-AT STORAGE 188 7649
238190 0.0 Call 135 Call Nuwer Auto Parts Inc.
716-537-2800
800-333-3031
716-537-2800
800-333-3031
7178 Vermont Hill Road
Holland NY 14080
95
BRONCO Console
RED 0 0858
52425 0.0 $60.00 190 Call BILL'S AUTO PARTS TOLLAND
860-875-6231
800-552-4557
Greg or Jeri
860-875-6231
800-552-4557
844 Tolland Stage Road
Tolland CT 06084
www.bills-autoparts.com
95
BRONCO Console
POW XLT GRY BUC AT BROKEN LATCH 0 100086
5584 0.0 Call 212 Call AUTO & TRUCK
yo Fred & Otto,
ok, thanks Fred.
grainger.com
That is not it. I'll see if I can get a picture of it. Total over all length is about 1". I will go to my local friendly parts guy today and see if he has them. The one in the picture is too big to fit in and the wrong shape on the end. The glass part on the correct bulb is only about 1/2 inch or shorter.
Ford644
