Capnbubb
Have a problem with the engine once it gets warmed up well. Wants to idle to low, like about 500 rpms. Any input on best way to adjust the idle. Has the 302 EFI.
First, try a Self Test for trouble codes, post them here.Have a problem with the engine once it gets warmed up well. Wants to idle to low, like about 500 rpms. Any input on best way to adjust the idle. Has the 302 EFI.
right, no OBD II on 90...but.............................. the self test is for that Year and there are scanners for EEC IVThe 1990 Broncos DON'T have OBD2. You can't put a scanner on it!
Is the EEC test any more accurate. I expierence with OBD II and have done most training on it.
some background for you;
1987 - 1995 Bronco (trucks, etc.) has EEC-IV - the processor is ok and good enough for DIY troubleshooting and does not need the $80.00 and up OBD II Code Scanner; can DIY with a section of wire or multimeter
1996 Bronco has EEC-V (OBDII) -
by Ford..."The EEC-V System is the fifth and newest generation of Ford
